Car Video Interface for Audi A6,A8,Q7 MMI Touchscreen
Postby Commander » 22 Jan 2013, 00:20
Today I got the interface. Now I am a little perplexed.
The A / V cable assignment is different in the installation diagram.
I have.
First-AV1 with RCA. If the input or output?
Second -AV2 with RCA. If the input or output?
Third -1x A / V RCA. Is this for headrests?
4th -1x video input. without RCA. R-Cam
5th -1x video input. without RCA. F-Cam
6th -1x V-out. For what?
and a second Question.
For what is the purple wire. Safe on electricity.
Regards Mike
Commander
Car: Audi A6 3,0 Quattro
Re: Car Video Interface for Audi A6,A8,Q7 MMI Touchscreen
Postby Chortenia » 22 Jan 2013, 15:49
What version of MMI do you have?
Postby Commander » 22 Jan 2013, 17:33
MMI 2G ,2006
Commander
Postby Chortenia » 22 Jan 2013, 17:55
av1,av2,av3 – inputs
av/out – video output (for example, to connect headrest monitors – the image displayed on the headrest monitors will be the same as on the in-dash OEM monitor)
rear c – input for rear view camera
safe – connect it to GND to enable image display when the car is in motion
Postby Commander » 22 Jan 2013, 19:17
As I said, I have. 1x AV Out for headrests ok.
and 1x video out alone whitout RCA for what he is?
Mike
Commander
Postby Chortenia » 23 Jan 2013, 10:57
What video out without RCA do you mean?
Please, provide the photo.
Postby Commander » 23 Jan 2013, 19:21
Ok I have two pictures !Image
and
can you see what i mean ?
Commander
Postby Commander » 23 Jan 2013, 19:30
I think those are the wrong cable for the interface.
The new version has 3 A / V inputs, and no F-cam input.
Is that correct?
Commander
Postby Chortenia » 24 Jan 2013, 12:27
F-cam is AV3 without audio. Use this output for the third source.
Postby Commander » 24 Jan 2013, 17:28
Then the following status: AV1, AV2, AV3 F-Cam.
Video with RCA, and video out is for the headrests.
R cam for rear camera.
Is that correct?
If the two outputs for headrest single switchable? :?:
Mike
Commander
Postby Chortenia » 24 Jan 2013, 18:38
Yes, you are right.
Please, explain your question.
Postby Commander » 24 Jan 2013, 20:17
Have I two outputs for headrest or not ?
Mike
Commander
Postby Chortenia » 25 Jan 2013, 11:31
Yes, of course.
Postby Commander » 25 Jan 2013, 18:03
Ok, so now everything is clear. Thank you.
Mike
Commander
Postby Commander » 02 Feb 2013, 22:17
So, I have now connected the interface and tested. The F-Cam connection is definitely not AV3 input. :evil: About the mode switch can I AV1 and AV2 switch. F cam switch I can but there is no video displayed. R cam I can power switch on the rear transition value but there is no video displayed. Do I need a different video format for R-and F-Cam ?
Can you send me the correct video cable? (With AV1, AV2 and AV3 terminal)
Mike
Commander
