Clock reset
Clock reset
Postby wildcat » 25 Mar 2013, 14:06
Right know I plugged in power supply in standard manner. So red wire is connected to ignition switch.
In result system clock settings resets every time I turn off the car.
Is there a way to hook up the power so it would only suspend the system or not volatile clock memory?
In standard car stereo there are two wires: one for battery connection (called memory) and one for turning on the unit (ACC).
Kind regards
Bartek
wildcat
Car: Infiniti FX45
Re: Clock reset
Postby Chortenia » 26 Mar 2013, 11:54
You can synchronize time via GPS, however this function is in the testing mode. Go to the autorun, GPS tab, check and choose COM1 port, rate 9600.
Re: Clock reset
Postby wildcat » 09 Apr 2013, 12:32
This solves the problem of time synchronization.
I have in my CS9100 one additional issue. During startup I got fatal error. Print screen is in attachment. If I will not tap the ok button then the GPS is not working. Do you have never version of Starter application?
wildcat
Car: Infiniti FX45
Re: Clock reset
Postby Chortenia » 09 Apr 2013, 14:52
Change COM1 for COM6 in the settings and try to adjust other settings.
Re: Clock reset
Postby wildcat » 09 Apr 2013, 17:45
I have COM2 chosen for GPS and this is valid port. If I change for any other number, I cannot establish communication with GPS module.
Nevertheless for every port setting I have such fatal error at the beginning. After tapping ok button everything come back to normal.
What Starter application do, beside starting the menu and navigation software?
wildcat
Car: Infiniti FX45
Re: Clock reset
Postby Chortenia » 10 Apr 2013, 14:27
Starter utility is in ccharge for the autorun, but it remained in the testing stage. Unfortunately, there are no new versions.
