Bluetooth
Bluetooth
Postby velecin » 22 Apr 2013, 20:46
Hello!!!
I have installed a CS9200 in my Range Rover Evoque with car Video Interface for Range Rover Evoque. Can I connect the bluetooth original with Car Video Interface for Range Rover Evoque (http://car-solutions.com/es/car-video-i ... evoque.php)????? Is it possible????
If I can´t connect it, can I use my original bluetooth while I am using the GPS (CS9200)? Make calls, picking ...
velecin
Car: Range Rover Evoque
Re: Bluetooth
Postby Chortenia » 23 Apr 2013, 12:24
All OEM functions are preserved.You can use the OEM Bluetooth, but you will need to switch to the OEM image to make calls.
Re: Bluetooth
Postby velecin » 23 Apr 2013, 13:29
But when I have to receive a call, do I have to choose the OEM image too??? Will ring my phone as usual if I have the image of the CS9200?? I'm a little lost!
velecin
Re: Bluetooth
Postby Chortenia » 23 Apr 2013, 15:06
The telephone will ring but the button to pick up the phone will be only on the OEM screen.
Re: Bluetooth
Postby velecin » 23 Apr 2013, 15:38
Ok!!!!
Thank you very much.
Kind regards
velecin
Return to Additional Equipment for CS9100/CS9200 Navi Boxes
