CS9200 and Navigation Programs
Postby sam274 » 30 Jul 2013, 03:50
Hi, I have a CS9200RV and Rhonson display (800x480 with touch).
I have been tested several Navi programs, as known Garmin XT, Navitel, iGO Primo 2.4 and iGO 8.
Some of them works, with some problems, others directly doesn't work.
Only iGO8 works fine. I were using during two days testing, before installing my car, all is OK, and suddenly, during the iGO8 running, the screen fill with colors lines, and touch didn't work any more. There is nothing to do, that can interrupt this wrong process,the unit is completed freeze. Only force shutdown, (cut +12V from Batt and ACC simultaneously), force to reset the CS9200RV and restart again. After restarted, the problem repeat again, and again.
Could be possible that some internal into the CS9200RV could change, during different s navi programs test?
Why, iGO 8 works fine during two days, and after that starts and freeze.
I need your help, to identify the problems.
sam274
Car: Volvo XC90
Re: CS9200 and Navigation Programs
Postby Chortenia » 30 Jul 2013, 10:23
1. Don't connect the BATT wire form the CS9200 navigation box.
2. Set the same touch control protocol which was before you changed it - Subaru RH2 protocol (PANEL tab)
3. Set the same image type which was before you changed it (RESOLUTIONS tab): 800x480 > 800x480 RHOSON D1 XC90
Postby sam274 » 30 Jul 2013, 19:07
Hi, I did it (but the previous configuration were correct, as same as you told me). Disconnect Yellow wire "Batt".
Restart, and same problem, y test with iGO8, iGO primo, Navitel, and same problem, a few seconds o minutes later than the navi programs runs, it hang.
sam274
Car: Volvo XC90
Postby sam274 » 30 Jul 2013, 19:25
HI, here you have a photo for the screen when it hang.
https://lh5.googleusercontent.com/-9lpm ... C_0005.jpg
https://lh3.googleusercontent.com/-NhkK ... C_0004.jpg
Probably yoy cab identify the problem.
sam274
Car: Volvo XC90
Postby sam274 » 31 Jul 2013, 04:24
Hi, the CS9200Rv is veri unstable, some of times when i try to start up it hangs, or WINCE show differents errors.
Can you give the information to flash it again.
This is the information of my device.
Seller: car-solutions ( 162 )
Item title Price Shipping price Qty Item total
CS9200 RV Navigation Box US $xxx.00 US $xx.00 1 US $xxx.00
( item: 251286938735 transaction: 1260327384015 )
Paid on 05-Jul-13
Shipped on 09-Jul-13
Expedited Int'l Shipping
Estimated delivery: You can contact seller for more information.
Tracking number: EA153340825HK
Thanks again
sam274
Car: Volvo XC90
Postby Chortenia » 01 Aug 2013, 17:20
You can find the manual on flashing inside the archive.
Postby sam274 » 01 Aug 2013, 20:59
Sorry, but I can't understand.
What I have to find, and where?
You are talking about the archive, What archive, where is it?
sam274
Car: Volvo XC90
Postby Chortenia » 02 Aug 2013, 09:30
Sorry, I forgot to give the link to the firmware.
Here it is
Postby sam274 » 02 Aug 2013, 18:28
OK, Thanks.
Do you know how to change the resolution (480x234) of Bluetooth application. Because is very small into Rhonson 800x480 resolution display.
sam274
Car: Volvo XC90
Postby Chortenia » 05 Aug 2013, 17:02
It's impossible. It's predefined by the manufacturers.
Postby sam274 » 05 Aug 2013, 18:16
Hi, could you give the information contact of manufacturer to explain the problem, and try to adapt the software for new resolution.
sam274
Car: Volvo XC90
Postby Chortenia » 06 Aug 2013, 13:00
We already informed the manufacturer several times, but they haven't fixed the problem. We will inform them once more based on your request.
Postby sam274 » 14 Sep 2013, 01:58
Hi could you tell me What other media player can we use with CS9200RV? Windows Media Player originally embedded is a lack app.
sam274
Car: Volvo XC90
Postby Chortenia » 16 Sep 2013, 16:40
Try our menu. You will find two players there.
Link to download the menu.
Postby sam274 » 17 Sep 2013, 00:07
Before run menu.exe, it necessary to do it from SDMMC, or from USB Storage?
sam274
Car: Volvo XC90
