CS9900 Navigation Box
Re: CS9900 Navigation Box
Postby pepeking » 21 Nov 2013, 12:56
would be interesting to indicate what are the improvements of each update.
pepeking
Car: AUDI Q7 AND Q5
Postby edgararroyo » 12 Dec 2013, 04:20
Trying 26-11-2013 to see if it stops freezing and if I notice any improvements. Also, Navigon started complaining it can't use the external sdcard, what's going on? extsd is not accessible from apps? I'm going to try to map it to /sdcard/Navigon/map that way I can store the maps in the extsd (if apps are capable of writting to extsd... This is going downhill, support never got my touch working and now this...) IDK but im not a happy customer...
edgararroyo
Car: VW CC Sport
Postby Chortenia » 12 Dec 2013, 13:21
We don't know how the Navigon works. For example, in the iGo settings file it is indicated where to look for the content. Everything is found on extsd.
As far as nonworking touch is concerned, if you are sure that you connected everything correctly and touch doesn't work anyway, contact the manager for repairs/replacement.
Postby edgararroyo » 12 Dec 2013, 15:23
I found this app and tested it last night, seems to be working. Only difference is that instead of "external_sd" like many other devices I used "extsd" which is what this device uses could be that some software looks for a certain map name? IDK... But I got it working! :)
Code: Select all
http://forum.xda-developers.com/showthread.php?t=1410262
edgararroyo
Car: VW CC Sport
Postby Triglia118 » 27 Mar 2014, 11:49
Dear friends,
I need your help to change the home launcher of CS9900.
I've chosen Launcher 4 as default launcher and now I'm not able to get back!
I'd like to change also the default home/launcher completely with something different available through Google Play. I know that this isn't possible officially, but I'm quite tech savvy and I'm not afraid to mess around with configuration files modifications.
I've already rooted the CS9900, but up to now I haven't been able to substitute / change home launcher.
So please teach me how I could manage this mod. Just some hints would be sufficient.
Thank you for your help
Triglia118
Car: Toyota Auris TS Hybr
Postby motoridersd » 28 Mar 2014, 04:07
I found some old posts about Bluetooth hands free for this box. Is this going to be supported (or is already supported?)
I'd like to do handsfree calls and A2DP audio.
motoridersd
Car: Subaru Legacy Spec.B
Postby Chortenia » 01 Apr 2014, 16:29
Unfortunately, we don't have solutions how to change the OEM launcher. To return the selection of launchers 3 and 4? do the following: Settings -> Applications -> Manage Applications. Find Launcher4 and select it. Hit the button that says Clear Defaults.
Postby Chortenia » 01 Apr 2014, 16:32
Unfortunately, CS9900 is not compatible with hands free operation.
Postby Raúl » 07 Apr 2014, 00:46
Buenos días, He recibido el sistema de navegación CS9900 para mi Toyota Verso de Dicembre del 2012 con numero de pedido 2810615 con fecha: 21.03.2014, y siento comunicarles que el sistema CS9900 me ha dado problemas, cuando se instaló funciono perfectamente los primeros minutos, venía con el idioma en español predeterminado y con todas las funciones funcionando perfectamente, mando a distancia, sistema táctil, gps... al cabo de un par de minutos el sistema comenzó a relentizarse, y al tocar la pantalla para seleccionar cualquier icono tardaba de 10 a 20 segundos en responder, fue a peor hasta que quedó bloqueado por completo y no repondia ni al mando ni a la pantalla táctil. Para poder reiniciarlo tuve que desconectar el cable de alimentación del CS9900, cuando reinició sufrio el mismo proceso, y si no desenchufas el cable del CS9900 no responde. Lo he intentado varias veces y siempre he obtenido el mismo resultado.
Por favor podrían indicarme los pasos a seguir para resolver mi problema, considero que es un producto cuyo valor es alto y no debería dar esos problemas.
Espero su respuesta lo antes posible.
Un saludo,
Translation
Good days, Have I received the system of navigation CS9900 for my Dicembre's Toyota Verso of 2012 with number of order 2810615 with date: 21.03.2014, and I am sorry to report to them that the system CS9900 has given me problems, when he established himself work perfectly the first minutes, it was coming with the language in predetermined Spanish and with all the functions working perfectly, I give the orders distantly, tactile system, gps ... After a couple of minutes the system began to go more slow, and on having touched the screen to select any icon it was late of 10 ones to 20 seconds in answering, it was to worse until he remained blocked completely and not answering neither to the control nor to the tactile screen. To be able to restart it I had to disconnect the power connector of the CS9900, when it restarted the same process took place, and if you do not unplug the cable of the CS9900 it does not answer. I it have tried several times and always I have obtained the same result. Please they might indicate the steps to me to continue to solve my problem, I think that it is a product which value is high and it should not give these problems. I wait for his response as soon as possible.
A greeting,
Raúl
Car: Toyota Verso
Postby Chortenia » 07 Apr 2014, 12:04
Postby Raúl » 07 Apr 2014, 23:13
Buenas noches desde España, gracias por la rápida contestación y por el aporte para arreglar los problemas con mi recién adquirido sistema CS9900 carsolutions edition, para un toyota Verso de Diciembre de 2012, probaré mañana la actualización para ver los resultados y os comento el resultado.
Quería haceros además una pregunta, he visto en uno de sus manuales del CS9900, que el CS9900 puede soportar "Mirror Link Function", pero que requiere una aplicación .apk, llamada HEADUNIT-DEBUG, sabeís donde puedo conseguir esa aplicación? La he buscado por la red y no he encontrado nada, o puede que haya traducido mal el texto?.
Entiendo que es posible conectar el samrtphone al sistema y generar "screen mirror", mi smartphone es un Samsung S4.
Muchas gracias otra vez y perdón si el traductor no traduce como es debido.
Un saludo.
Translation
Good nights from Spain, graces for the rapid answer and for the contribution to solve the problems with my newly acquired system CS9900 carsolutions edition, for my Toyota Verso of December, 2012, I will prove tomorrow the update to see the results and I comment on the result to you.
It wanted to do to you besides a question, I have seen in one of his manuals of the CS9900, that the CS9900 can support " Mirror Link Function ", but that needs an application .apk, called HEADUNIT-DEBUG, they might say to me where I can obtain this application? I have looked for her for the net and have not found anything, or it is possible that he has translated badly the text?. I understand that it is possible to connect the smartphone to the system and to generate " screen mirror ", my smartphone is a Samsung S4.
Thank you very much again and pardon if the translator does not translate since is due.
A greeting.
Raúl
Car: Toyota Verso
Postby Chortenia » 08 Apr 2014, 09:47
Mirror Link Function is available only for boxes with HDMI. We don't have such box in our product range, and apparently, won't have.
Postby Raúl » 10 Apr 2014, 16:58
Thank you for his response, but I feel a bit cheated by this topic, in one of his manuals there comes specified that can realize this function and not to speak anything about HDMI, but of an application android.apk, in fact it was one of the motives to buy the article, if not why it was going to pay 500 Euros for an android 2.3, so ancient. My anger increases when one week later poneis to the sale a system android 4.1 with HDMI that yes might do this function and cheaper. I regret having this opinion but really I feel a bit defrauded, a companion of work also was interested in your products but I will not be able but to give him slightly positive references.
A greeting.
Raúl
Car: Toyota Verso
Postby Chortenia » 17 Apr 2014, 11:38
Dear customer. We strongly recommend collecting all information about the product before purchasing it. We have a thorough description of the product on its page, also you can ask our sales managers in the chat, via e-mail or by the phone, and also our technical specialists in the chat or via e-mail. They will answer all your questions and help to select the product you need.
We are really sorry you didn’t buy the device you needed and we hope your further experience with us would be much better.
Postby Raúl » 17 Apr 2014, 23:11
Thanks for your reply , I understand your explanations and I share is always necessary consulting the manual , so before buying I read the manual , and as you can see such a function is included in the manual, I attached photo showing what I say . And says nothing about HDMI , but on an android application apk .
That is why I reaffirm what expressed in the above post , I feel a bit cheated with this, should remove that information from your manual , it does not seem fair to pay for something that I'm really going to enjoy , and as I expressed was that feature one that led me to choose this product , especially when the product has a very old version of android .
Finally I think this is unfair to me, I had no blame for anything more than to buy one of his informing me before and at their manual products , and now I must do again , to pay for the new android 4.0 system that will you bring to market , which may itself perform that function because it takes HDMI ?
It seems a rather unfair ...
Raúl
Car: Toyota Verso
PreviousNext
Return to CS9900 Navigation Box
