Audi A3 - Installation Wires
Postby luisfshitakubo » 12 Jun 2014, 20:36
Hi There,
I have the Audi A3 2013/2014 8V or MQB Platform with the STD 3G MMI
And After removing the Command Unit, removed the quadlock connector of it and would like to confirm if anyone here have all the wires colors/scheme diagram to make the correct connections right there, without the need to splice any wire of the oem system.
The wires needed are the CAN wires, NAV button wire, ...
I've purchased the extension cable available at ebay Germany and Will use it to make the right connections.
Thanks!
Luis F. Shitakubo
luisfshitakubo
Car: Audi A3 2013-2014
Re: Audi A3 - Installation Wires
Postby Chortenia » 13 Jun 2014, 15:28
We don't know about the HU socket pinout. The climate control socket pinout is orange+violet = GEAR CAN-H, orange+brown=GEAR CAN-L, orange+black=mmi CAN-h, orange+brown = mmi can-l
Postby luisfshitakubo » 27 Aug 2014, 05:45
Chortenia wrote:Hello
Thanks for your reply.
How about the others 3 wires?
Safe (purple)
Mmi (white)
F can det (light blue)
What are the correspondence for those?
luisfshitakubo
Postby Chortenia » 28 Aug 2014, 11:02
There's no need to connect these wires:
Safe (purple) - when connected to GND.
Mmi (white) - NC
F can det (light blue) - NC
Postby luisfshitakubo » 29 Aug 2014, 01:47
Ok, I've made all the connections, turned the ignition to acc... the display goes up and nothing happens... I tried pressing the remote button, but nothing. All I get Is a green and a Red light on the LVDS unit, but no access to it... What I am doing wrong?
luisfshitakubo
Postby Yuretz » 03 Sep 2014, 17:57
luisfshitakubo wrote:Ok, I've made all the connections, turned the ignition to acc... the display goes up and nothing happens... I tried pressing the remote button, but nothing. All I get Is a green and a Red light on the LVDS unit, but no access to it... What I am doing wrong?
Could you provide photos of how everything is connected and in what positions DIP swithes are?
Postby luisfshitakubo » 03 Sep 2014, 18:02
when I press the mode button of the LVDS it goes over the screen but I can't activate lvds by using the steering or nav button.
Should I change something?
luisfshitakubo
Postby Yuretz » 05 Sep 2014, 12:42
luisfshitakubo wrote:when I press the mode button of the LVDS it goes over the screen but I can't activate lvds by using the steering or nav button.
Did you connect CAN wires as it's shown in the manual page 8(11) ?
Postby luisfshitakubo » 18 Sep 2014, 04:03
I change the wire positions of my cable as suggested by Chortenia on the other topic
Now, looking from upside, from left to right it goes like these:
Brown
Black
White
Grey
purple
blue
brown
purple
black
red (+12v)
I can go to AV1/av2... by clicking on the nav button on the console.
And Now I have signal when gear is on Rear for the rear can
The problems I'm facing now is
1. the PAS lines don't do dynamics when I steer the wheel.
2. The nav button of the steering wheel still doesn't work.
What could be wrong right now?
luisfshitakubo
Postby Chortenia » 19 Sep 2014, 16:01
Please, provide the photos how power cable is connected and how CAN-H CAN-L wires are connected. the colours of the wires shoul be visible.
Postby luisfshitakubo » 30 Dec 2014, 15:52
Everything now seems to work fine except.. the power consumption. I used de ACC and Yellow wires of the MMI 3G to Connect my Unit, but I left my car parked for 3 days and it drained almost my battery. Could have something wrong with my unit? It heats up a lot too.
What could be happening?
luisfshitakubo
Postby Chortenia » 05 Jan 2015, 12:44
As we can judge the video interface is powered not by АСС, but by BAT. Did the LED on the video interface shine when the ignition was off?
Users browsing this forum: No registered users and 27 guests
