Ap-rgb1 cable.
Ap-rgb1 cable.
Postby Mightyjoe » 04 Aug 2014, 04:38
I'm installing the cs9320 on my alpine system. The touch screen is not yet working. Where do I connect the red and black wires coming out of the data cable of the ap-rgb1?
Thanks for your help.
Mightyjoe
Car: Lexus gs300
Re: Ap-rgb1 cable.
Postby Chortenia » 14 Aug 2014, 17:10
Red is for rear view camera activation. Connect it to the rear lights lamp. Black is mute, don't connect it anywhere.
Which protocol and radio model is selected in 9320 setting?
Re: Ap-rgb1 cable.
Postby Mightyjoe » 15 Aug 2014, 03:58
Thanks for your reply.
I've already completed the installation and found after checking all functions were working correctly that I did not need to connect the red and black wires as im not using a reverse camera.
Mightyjoe
Car: Lexus gs300
Re: Ap-rgb1 cable.
Postby Mightyjoe » 22 Sep 2014, 04:44
Just another question regarding this cable connection. (Everything is working well)
Because the unit is connected through the Alpine navigation plug in, I think the sound only plays through the front speakers.
This is good when using navigation but not so good when playing something like music from the CS9320.
Can you suggest any solution?
Mightyjoe
Car: Lexus gs300
Re: Ap-rgb1 cable.
Postby Chortenia » 26 Sep 2014, 17:25
When CS9320 is connected to Alpine head unit, audio works the same way as with the OEM navigation. It is transferred to the driver speaker or two from speakers. Connect sound from CS9320 to the car AUX to transfer the sound to all speakers.
