Mightyjoe wrote:Hi,
Just an update on the situation.
I tried to reformat and update with the different files you gave to me. Unfortunately both times the screen was stuck on 'Navigation system loading...". I waiting each time for about 10 mins.
I still had the first update file you gave to me when I first came to you with this problem so I just reinstalled that.
Screen Density is still set at 300.
Mightyjoe wrote:Can you please resend link to the update file?
I just want to be sure ive got the right one.
The current update files I have wont go past the 'Navigation system is loading..' screen.
neriano wrote:Hi,
I have the exact same problem, tried to change touch density and now everything is too big to be accessed. Unfortunately the last update file does not work for me. Could you please send me an update file that will reset the touch density, or, all settings to factory default?
Thank you very much.
George
neriano wrote:It worked, thank you!
Another question, please. I connect to Bluetooth with no problem. I can hear everything vhappenll but my callers cannot here me. Same with skype and Viber. The microphone works fine, otherwise, I have tested it in other applications. Any idea why this is?
Thank you very much
Users browsing this forum: Majestic-12 [Bot] and 4 guests
