as I can restart CS9200
Postby kikasso » 14 Dec 2014, 23:58
as I can restart CS9200 because when I plug in the iphone to entry in to view videos only works sometimes also the picture looks but no sound cables I use are original
e seen in the manual the reboot option but not to this that option to mark
kikasso
Car: opel vectra c
Re: as I can restart CS9200
Postby Chortenia » 18 Dec 2014, 15:52
We didn't quite understand the issue.
Could you please explain it more?
Postby kikasso » 18 Dec 2014, 19:41
the problem is this, when I plug the iphone to watch videos in 9200 with the original cable you buy and insert it at the entrance to 9200 in sometimes works and sometimes does not work. I thought it would but I plug the cable into the tv and it works correctly but in 9200 not as light unplug the 9200 works well and I think it will get stuck and so see how to restart to try if that the problem is to discard things until you see the problem or if you know you will because that sometimes works and sometimes not
kikasso
Car: opel vectra c
Postby Chortenia » 19 Dec 2014, 15:12
Which cable for iPhone connection to 9200 have you bought in our store?
