conexion bluetooth a2dp
Postby dcarbo » 05 Sep 2014, 21:34
Hola. Estoy intentando emparejar el modulo de navegacion cs9320 con mi range rover evoque por bluetooth pero no puedo. Al dar a buscar dispositivos no lo encuentra. Con otros telefonos android puedo hacerlo sin problemas. Que puedo hacer??
dcarbo
Car: range rover evoque
Re: conexion bluetooth a2dp
Postby Yuretz » 09 Sep 2014, 09:33
For Bluetooth, please use AwdSdkSample application.
Postby dcarbo » 06 Oct 2014, 02:26
I can`t conect any bluetooth device, pair, a2dp...doesn't work
dcarbo
Postby Chortenia » 07 Oct 2014, 12:16
What device do you want to pair up? If it's a telephone, what exactly is not working. Please, provide the video of the problem.
Postby dcarbo » 17 Oct 2014, 12:51
Hello. I can`t pair the cs9320 with my range rover evoque. i wan`t use it with a2dp to get audio on the car. i can`t pair the cs9320 with my smartphone lg g2 too.
I read on this post, viewtopic.php?f=647&t=30380, and i see that there are problem with bletooth that should be fixed in 4.3 update. when will be available this update??
dcarbo
Postby Chortenia » 17 Oct 2014, 15:49
To install firmware on Android 4.3, do the following:
Download this archive and place its content on the empty memory card. Wait about one minute until such message appears:
and turn off the power.
Then place this archive into SD card root and apply the power. The process will take nearly 3 minutes. After that the box will reset.
Please, note: after firmware update all installed programmes will be deleted, and settings will be reset to the factory one. You will need to set the right control protocol and screen resolution.
JB43_Partition firmware update should be performed once. I.E. if it has already been done, then, for example, if you downgrade to 4.1.1 and then again upgrade to 4.3, you don't need to update JB43_Partition once more.
Android 4.1.1 firmware.
best regards,
Postby myideal » 24 Dec 2014, 09:41
hello
i want update my cs9320 to 4.3
i put the first files in sd card and is ok sem photo in this topic
after i put the secund file for update but coming update false !!!
and now my device not working only writing '' navigation system is loading ''
i try put update file 4.1.1 but is sem message '' update file false ''
please help
thank you
best regards
myideal
Car: lexus
Postby Chortenia » 24 Dec 2014, 11:16
What and where did you write for update?
Postby myideal » 24 Dec 2014, 13:13
hello
here on this forums
myideal
Car: lexus
Postby myideal » 24 Dec 2014, 14:05
ok
anyway please help me
my device not working and only coming this
thank you
myideal
Car: lexus
Postby Chortenia » 25 Dec 2014, 11:27
Write wp9920_update.zip file on the memory card. Don't rename the file and don't unpack it. Insert the memory card to the device and apply power.
Users browsing this forum: No registered users and 10 guests
