No Navigation massage on kenwood DDX8024BT
Postby oferelijah » 06 Jan 2015, 20:16
yesterday i got "No Navigation" message on my kenwood DDX8024BT unit.
when i am connecting a monitor to the CVBS output all looks fine.
didn't change any settings in the last month.
the LED of the 9320 unit flashes green and red.
any help?
oferelijah
Car: Golf GTI
Re: No Navigation massage on kenwood DDX8024BT
Postby Chortenia » 08 Jan 2015, 16:46
Most likely RGB or DATA cable are disconnected. Also check the head unit settings. Maybe you disabled navigation support. Check the control protocol on 9320.
Postby oferelijah » 08 Jan 2015, 18:16
Thank you,
i checked that and nothing is disconnected..
this looks like my problem.. will this update will work for me?
viewtopic.php?f=647&t=30478
oferelijah
Car: Golf GTI
Postby Chortenia » 09 Jan 2015, 17:04
You can connect the box via CVBS and check, whether the resolution and control protocol are set correctly.
This update just restores the factory settings.
Postby oferelijah » 09 Jan 2015, 17:48
I checked in the cvbs all looks fine.
I checked the ken-rgb cable and it's looking good also.
It's really frustrating...
How can I restore all settings to default?
When i put this update file on the root of the SD card and restart the box, nothing happens i have WAZE app loading automatic on loading.
What else can I check?
Thank you for your support.
oferelijah
Car: Golf GTI
Postby Chortenia » 12 Jan 2015, 16:05
What is selected in the Display/Screen settings?
Postby oferelijah » 12 Jan 2015, 18:51
It was kenwood 7039
It was ok.
I tried to restore to default and then set the screen and touch setting again and niw it's working, strange but at least now it's working.
thank you for your support.
oferelijah
Car: Golf GTI
Postby oferelijah » 06 Mar 2015, 19:44
Again same problem
All the setting are correct. And still no display on the navigation on the RGB input.
In the monitor Cvsb all looks good.
I know that the cable ken-rgb1 is good because i connected the old cs9100 that i have and its working fine.
What can it be now?
Reset to defaults and set again to panel Kenwood with resolution and touch of ddx7039 didn't work.
What am I doing wrong?
oferelijah
Car: Golf GTI
Postby Chortenia » 16 Mar 2015, 17:19
Settings->Display->Screen change->Advanced settings: resolution - 480х234, Kenwood panel - try everything, touch - Kenwood 7039
Postby DxL » 08 Apr 2015, 11:33
Any news? Is it working fine on KENWOOD DDX8024BT or not?
DxL
Car: Hyundai i30
Users browsing this forum: No registered users and 4 guests
