Problem Mirror Link Audi A6 4F
Postby mapi » 13 Feb 2016, 11:11
Hi @ all,
I bought a MirrorLink unit after being connected, this is the result: the image appears in black and white and the image is replicated as photos attached
Please me, send one solution.
Thanks and best regards
Image Black and white ...no color
mapi
Car: A6 4F
Re: Problem Mirror Link Audi A6 4F
Postby Yuretz » 15 Feb 2016, 10:35
Please provide your order number and specify how have you connected the mirrorlink adapter to the OEM display.
Postby mapi » 15 Feb 2016, 14:13
hi at all
Mirror link connected to the display oem through RCA cable (red white yellow) I have the car solution order number because I have not bought from car solution but being all the same, that's why I wanted to ask you if you know to solve the problem.
Warning: I have not bought from car solution
thanks and best regards
mapi
Car: A6 4F
Postby Yuretz » 15 Feb 2016, 18:40
It seems that this adapter is transmitting video signal in NTSC standard and your car supports only PAL. You can change the standard in the video settings of this adapter via AirFun application or via browser.
Also, It might not work while the car is in motion.
Postby mapi » 16 Feb 2016, 14:00
Hi, very nice to your answer.
Yes, you're right, you have to set the correct display via browser.
Thanks so much!!
mapi
Car: A6 4F
Postby Yuretz » 16 Feb 2016, 14:07
You're welcome.
