Evoque my17 monitor 10.2"
Postby lanciadeltaevo » 21 Jan 2018, 13:59
has anyone tried if it works well I know 10.2 "?
https://car-solutions.com/en/video-inte ... 016-my.php
lanciadeltaevo
Car: Evoque
Re: Evoque my17 monitor 10.2"
Postby Yuretz » 22 Jan 2018, 11:06
It works well with InControl Touch Pro head units.
Postby lanciadeltaevo » 22 Jan 2018, 14:31
I already have the navigator and the rear camera. does everything work automatically? Can I insert the front camera? does the Bluetooth work with the original speakers or with the supplied speaker?
lanciadeltaevo
Car: Evoque
Postby Yuretz » 22 Jan 2018, 14:38
What do you mean?
Yes, you can.
OEM bluetooth will work as before.
Postby lanciadeltaevo » 22 Jan 2018, 14:44
passes alone to the camera then returns to q-roi2? in R. the voice of the navigator works with the speakers of the car?
lanciadeltaevo
Car: Evoque
Postby lanciadeltaevo » 22 Jan 2018, 14:45
do you have a video as an example?
lanciadeltaevo
Car: Evoque
Postby Yuretz » 22 Jan 2018, 15:19
Video interface doesn't transmit sound to the OEM audio system. It can only switch between connected sound sources. You should connect the linear output of the interface (AV OUT cable) to the AUX input of your car.
Unfortunately, no.
Postby lanciadeltaevo » 22 Jan 2018, 15:28
incontrol touch pro does not have AUX input or at least I do not think so
lanciadeltaevo
Car: Evoque
Postby lanciadeltaevo » 19 Apr 2018, 08:43
sorry but if I connect in hdmi the q-roi2 to 'interface how do I listen to the sound of the installed applications? for example if I want to see a video on YOUTUBE the audio where it passes?
lanciadeltaevo
Car: Evoque
Postby Yuretz » 19 Apr 2018, 08:55
lanciadeltaevo wrote:sorry but if I connect in hdmi the q-roi2 to 'interface how do I listen to the sound of the installed applications? for example if I want to see a video on YOUTUBE the audio where it passes?
The sound goes to speaker and AV OUT outputs.
Postby lanciadeltaevo » 20 Jun 2018, 21:39
sorry for the latest firmware version of the interface that works well on monitor 10.2 "is the rev.1.4 thanks for your answers.
lanciadeltaevo
Car: Evoque
Return to Video Interfaces for Lexus, Toyota, Land Rover
Users browsing this forum: No registered users and 8 guests
