Toyota Land Cruiser 2005
Re: Toyota Land Cruiser 2005
Postby David » 02 Mar 2011, 19:53
Can you help me, please.
Toyota Land Cruise VXL 2005
CS9100 + NAV2NAv + LOW-END ( in process...)
David
Postby Germes » 02 Mar 2011, 22:00
Tomorrow I will gather the demo booth with RGB video interface and check everything.
Learn to write insults on the sand and to engrave on the stone of joy.
Germes
Car: eNOTE was broken :(
Postby David » 04 Mar 2011, 19:00
Do you know something of how to solve the problem?
David
Postby David » 09 Mar 2011, 23:16
I am still waiting for their response to solve the problem of video...
David
Postby David » 14 Mar 2011, 20:58
I am still waiting ...
David
Postby David » 21 Mar 2011, 23:49
Find it me shameful behavior that are taking.
I send a wrong device (cs9100 cs9100rv down), as a solution, send the device wrong and be 3 weeks without a browser, or buy another device.
Make me buy another device to resolve the error, that does not work..., solution... None.
And to fix this I leave to my fate.
Of course if someone asks me my opinion on the forums I visit your company I imagine that knows the answer...
Two purchases, a shipping error and another that does not work.
Total success.
Congratulations and thanks for nothing.
David
Postby Germes » 23 Mar 2011, 16:27
Hi, David.
I’m sorry for not answering but I was busy developing support for 2010-2011 Toyota/Lexus.
So, I made testing bench consisting of the following components:
1. OEM display Lexus RX300 2004 year
2. CS9100 navigation box
3. Video interface RGB LE (with set DIP switches: 10100110, where 1-ON, 0-OFF)
4. Universal rear view camera
5. HD Player Asus R1 with Firmware 1.29NTSC
When I switched it on:
1. Image via RGB was perfectly displayed.
2. When I shifted to AV1 or Rear Camera image in the upper part was notably trembling.
Solution:
Set DIP switch #6 on the video interface into OFF position. Actually in this mode we activate interlacing. It is written in red letters in the manual on the 12th page.
Conclusion:
Please, read manuals carefully!
Please do it and write whether it helped in solving your problem.
Germes
Postby David » 06 Apr 2011, 23:28
Sincerely you would not answer, because I want to leave as a fool who can not read...
As expected not has helped me solve the problem.
Fortunately we read and I read the instructions. As there will be read you, I suppose, in previous post because comment you that he had tried the DIP convinaciones.
Because you did not know, or know, which is the problem because I got in touch phone with a technical Spanish, in the same call gave me the solution.
It already works.
The problem is that the signal of video of the peripherals came as PAL and should enter as NTSC.
It is obviously a problem that has nothing to do with you, but with those who sold me the peripherals, but me strange that you do not know which was the problem.
In any case already fixed this.
David
Previous
